What Escape Character for a comma is recognized by Survey123?
2742
7
04-24-2017 10:06 AM
by Anonymous User
Not applicable
Hello all,
I have a csv file with fields containing commas (escaped with double quotes) to be used with the PullData() function in Survey123.  Survey123 doesn't recognize the quotes.
Example: -1,0000F5,"Albright's Mill, Vonada Enterprises, Inc. d/b/a",,,,,,1061 Kryder Rd
Is there an escape character which Survey123 does recognize?
Jim
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Jim,
Currently, there isn't an escape character for a comma.  We have plans to improve the parsing of CSV files in the future.
JamesTedrick
Hi Jim,
by Anonymous User
Not applicable
Understood.  Thanks James.  -Jim
DelaereMickael
Occasional Contributor II
hello,
I have the same problem. Has the parsing of csv file been improved?
JamesTedrick
Hello,
At this time, no changes to csv parsing have been implemented.
DelaereMickael
Thank you James.
TedChapin
Occasional Contributor III
How about now?
JamesTedrick
Hi Ted,
There is no update on this issue.  If you want to, you can ask Esri Technical Support to attach you to BUG-00009921 to keep track of this.
