webform issue after After Survey 123 September 2021 update: Create web form' enabled. Error: Missing .webform file
6562
34
09-24-2021 05:49 AM
WetherbeeDorshow
New Contributor III
Since the September 16 update, several surveys no longer work in the webform, even after rebuilding and republishing the survey using the latest version of Survey 123 Connect.
We get this error -
This survey cannot be accessed in the web app. Please contact the survey owner to republish the survey with 'Create web form' enabled. Error: Missing .webform file.
Press here to try to open this survey in Survey123 field app (installation required).
Interestingly, when I look at the webform that gets created successfully during the publishing process, the content of the .webform file is as follows:
"error": {
"code": -1,
"details": [],
"message": "Error: [object Object]"
"success": false
This issue appeared immediately after the September 16th update, prior to any efforts to republish or change the form.
Thanks!
3 Solutions
JamesTedrick
Esri Esteemed Contributor
Hi @WetherbeeDorshow ,
This is most likely caused by an error that was addressed last night with an update to the website, relating to the presence of an audio question in the form. Please republish the survey and see if the issue is addressed.
HaroldHerrera1
Yes, we are using external choices.
Kanin
by Esri Contributor
Hi all,
Based on this blog: What's new in ArcGIS Survey123 (December 2021) - Esri Community
BUG-000144749 Survey with external selects published from ArcGIS Survey123 Connect cannot be accessed in the web app, and returns the following error message, "This survey cannot be accessed in the web app. Please contact the survey owner to republish the survey with 'Create web form' enabled. Error: Missing .webform file."
The defect above has been fixed in the December 2021 release of Survey123 website. Please do see if the issues has been resolved in your survey forms.
Kudos to @IsmaelChivite for the updated release of Survey123!
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
JamesTedrick
WetherbeeDorshow
New Contributor III
Yep, that did it! Thanks
MatthewThomas8
I was having this issue today. Was there a new updated to Survey 123 connect creating this issue again?
Im trying to edit an existing survey submission on a web app.
using parameter below, in a configuration pop-up.
https://survey123.arcgis.com/share/2c970fa4acfb4e23a9b3dee7f86f8a68?mode=edit&globalId=5c141ba4-5a65...
from the screenshot you can see it is passing the Global Id, however it is saying the webform has an issue?
Im currently on Survey 123 3.16.
HaroldHerrera1
Hi @JamesTedrick
Today we have a similar error when republishing an existing survey that was published months ago! The survey doesn't use an audio question. The survey used existing "feature service".
It was designed with Survey123 Connect V.  3.13.234.
When we try to access from web access, the error show is this:
When the survey is published again, we enable to create webform option:
Webform file content is:
It's very important for our project, correct the error as soon as possible.
Do you know how to fix the error?
FionaBarry
New Contributor II
We are also experiencing this issue.
Our survey was working fine and we republished it yesterday (22nd November 2021) with a minor field change and are now experiencing this error.
I republished a test survey today (23rd Nov 2021) with no changes made, and are now receiving the same error for that test survey.
Please advise, thank you.
Edit: I updated to the latest S123 Connect Desktop app (v3.13.249) - still experiencing the issue
HaroldHerrera1
Our workaround was to republish the survey with a previous Survey123 Connect version (3.11) until the bug is fixed, and works fine.
YuliaMamonova
Occasional Contributor III
Hello, how can I download 3.11 version?
YuliaMamonova
Republishing with 3.10 has not fixed the issue with the webform.
MJBiazar
There has been reports of similar issues and we are trying to narrow down the issue to identify the root cause. Can you please confirm if you are using external choices in your survey?
MJ
@WetherbeeDorshow @HaroldHerrera1 @FionaBarry
