Web survey "failed to submit: - D is null"
395
01-29-2021 07:11 AM
JamesCollins
New Contributor II
I am getting an error "Failed to submit: - D is null" on a web survey.
This problem seems to be related to "file" type inputs on the form. It did not start until I converted some "image" inputs into "file" inputs. The Javascript console logs the following error on submit:
Uncaught TypeError: D is null
getFilesfromInput https://survey123.arcgis.com/share/v3.11/app-commons-v3.11.20.chunk.js:2
getQuestionVal https://survey123.arcgis.com/share/v3.11/app-render-v3.11.20.chunk.js:2
postOnQuestionValueChangedMessage https://survey123.arcgis.com/share/v3.11/app-commons-v3.11.20.chunk.js:2
markQuestionChange https://survey123.arcgis.com/share/v3.11/app-commons-v3.11.20.chunk.js:2app-commons-v3.11.20.chunk.js:2:193566
The survey was first created in March - April 2020, and I'm now resuming work on it using XLSForm in Survey123 Connect v 3.11.123.
I have tried duplicating the survey into a new survey and changing sharing settings. There's no other input validation problems until I get to the last page with the submit button, when I get the "Failed to submit: - D is null" error.
Has anyone else had this issue and been able to resolve? Thanks!
Tags (1)
JamesCollins
New Contributor II
I seem to have resolved the problem. The issue was that I had left the "annotate" option in the appearance field on the inputs I had changed from "image" to "file" type. After removing the appearing option on the file inputs, I was able to submit the form.
