This form was created in Survey 123, brought in to Survey123 Connect to add a couple of formulas, then posted back to Survey 123. Not sure if that might have something to do with it?
Although, the location map not showing up, was created and shared just in Survey 123.
thanks
Hi Pete,
Have you made sure the latest version of the form has been downloaded to your devices? When you say the multiple choice questions are not working, what is the behavior that you see? By the location map not showing up, are you not seeing the entire question or just the map?
