Way to have Grids align top vs bottom?
1190
03-25-2021 12:10 PM
DougBrowning
MVP Esteemed Contributor
Is there a way to align this at the top vs bottom to remove the spaces?
This gets pretty weird when the lists are much diff
I do not think so but checking on it
Thanks
IsmaelChivite
Esri Notable Contributor
Sorry @DougBrowning   There is no trick to change that behavior
IsmaelChivite
abureaux
MVP Frequent Contributor
This one has been bothering for for a while. I keep checking on-and-off to see if it will just magically work.
Since I didn't see a pre-existing idea for this, I just made one: https://community.esri.com/t5/arcgis-survey123-ideas/allow-text-in-grids-to-align-top-vertical-align...
