Viewing Survey Data in Survey123
4439
20
11-19-2019 11:26 AM
AdelaideZumwalt1
Occasional Contributor II
I have a survey based on a feature class in a enterprise database. Users can add to the survey with no problems but none of my viewers can see the data using Survey123 "Data." They get the following error:
The collaborate tab says that viewers can see "All records in this survey."
Why is it that I (who published the survey) can see the data, but no one else can? It is shared with everyone in ArcGIS Online and in Survey123.
I see the following on ESRI's site, but we are on version 10.6 so was this never changed?
I get thI get
"Feature layer views aren't supported for federated feature services and aren't available in ArcGIS Enterprise hosted services before version 10.6."
I called ESRI and got the following response: "Seems like the only way to allow for edits from survey123.arcgis.com is to use a hosted feature service from ArcGIS online." This just seems odd as I can edit the survey, but others can't (unless they are adding a new record). Any insight would be appreciated.
GingerHarrington
You are welcome!  Glad it worked!
