Hi Phil,
So, my XLS has keywords (the 'name' parameter is/has always been present since the XLS was initially published), and I am using the following query statement in the begin repeat row of the bind::esri:parameters column: query allowUpdates=true
I am not using any query statement in the Image row(s) however, and after re-reading the documentation I am unsure if maybe that is my problem. Specifically here, under Images in the second paragraph, it states that if I do not want users to be able to add new images, I should add a query statement "allowAdds=false" in the bind::esri:parameters column.
Also, these images have mostly (probably all) been added directly from the Survey123 field app on each end user's iPad, although there could be a mix of the users taking photos with the camera and attaching photos via the "file" option.
However...I did just republish the data because I needed to make some schema changes before I could make some updates to the survey. Would this impact the ability of the photos to show in the Inbox, even if they were all originally captured via the field app?
See here for example of XLS Form parameters - this is the main repeat:
This is the nested repeat:
Thank you for the help.
Erica
