Using the bind::esri:fieldAlias in Survey123 Connect
1844
02-16-2018 10:00 AM
AaronButterer
New Contributor II
I think I am having trouble with the sytax for the fieldAlias in Survey123.  I am trying to have the label field appear in the exported csv but it is still providing the name field.  This is what I have in the survey spreadsheet.
Tags (3)
BrandonArmstrong
Hello Aaron,
It looks like the behavior you are referring to is related to the 'select_one' questions in your survey.  Please take a look at the previous GeoNet forum thread, which highlights the following...
"This is a known issue with select_one questions. The data itself is written as the name column and a domain is created to so that the labels seen in Survey123 will be seen in ArcGIS Online; in all but file geodatabase exports, ArcGIS Online provides the code (choice names) instead of labels.  You can export the data with the labels via ArcGIS Desktop tools - see Problem: Coded value domain descriptions are not maintained after exporting data"
Please let me know if this is not related to your question.
Brandon
AaronButterer
New Contributor II
This sounds like the problem I am running in to.  Too bad.  Thanks for your reply!
