Using Survey123 app Hybrid Imagery Basemap do not show!
785
12-18-2020 11:55 AM
DiegoLlamasOlivares
Hello,
I have a survey hosted in Portal for ArcGIS 10.5.1 with submission URL. I use this survey for a police department and they add incidents that happened at the municipality but
We have a Survey field map that is consume in survey 3.7, 3.11 and 3.6.
In version 3.11 we do not see basemaps, just one, imagery
In version 3.7 i see more basemaps but I do not see hybrid imagery.
In version 3.6, like 3.7, i see more basemaps but not hybrid imagery
I sign to my AGOL account and I am able to see more basemaps. Could this be because incompatibility with versions? technologies? etc?
what could be happening with basemaps in my portal 10.5.1?
by Anonymous User
Not applicable
Hi @DiegoLlamasOlivares,
With version 3.11 (actually from 3.10 onwards), we now support Standard maps as default, and the Basic maps support is now off by default.
Standard maps uses the runtime and vector basemaps set in your Organisation by default, whereas Basic uses a predefined list of raster basemaps available in AGO or Enterprise organization.
Please refer to: https://doc.arcgis.com/en/survey123/desktop/create-surveys/includemap.htm#GUID-31B9C45D-8D07-4F0F-A3...
You can switch back to Basic map types in both Connect and the field app using the Settings menu, to see the older raster basemaps, otherwise make sure the Organization basemap group set in your AGO or Enterprise organization includes all the basemaps you want to see.
Regards,
Phil.
