Using Pulldata to populate geopoint from .CSV
1103
04-21-2021 04:25 AM
Kimbers
Hello
Similar questions have been asked before but I can't quite get the result I'm looking for.
I have a .csv with coordinate information in (what I think is) the correct format. It is saved in the media folder
I've tried using the Pulldata function in the Calculate field for the Geopoint question.
Is this correct or am I missing a step? Is it even possible? Perhaps it's just that I'm unsure of the correct syntax?
Any advice would be appreciated
Many thanks
Tags (3)
Ismael
Hi. Check this article: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-working-with-uk-po...
You can create a cleaner csv keeping the latitude and longitude values separate. The calculations will be more straightforward that way too.
Kimbers
Brilliant, thank you for replying so quickly @Ismael
I'll have a go at this and let you know how I get on
