Hello! I have a survey where I have users draw a polygon on a map and fill out a few questions. I am trying to save each response to Google Drive or have it emailed to me, but am unable to save the polygon area as an attachment (preferably as a .shp). Is this a feature that is available while using Integromat? Thanks.
Hi This is not something you can do easily. The webhook payload carries the geometry of the polygon in JSON format. My first go-to place would be https://community.safe.com/s/forums Using FME you will likely be able to do the conversion, which could be integrated with Integromat or treated as a separate webhook.
Thank you this is very helpful. I will attempt this.
