One of our partners is doing work in Ghana and would like to use the Dagbanli translation in the form, but it isn't on the ISO 639 list of languages. Is there a workaround or option to add a Dagbanli translation into our survey without causing other issues?
Hi Kevin,
While the examples in our documentation use ISO-639 2 character codes, you can also provide the ISO-639 3 character code (in this case, Dagbani (dag) ).
Thanks James! This worked perfectly
