Using Collector to edit a sent survey
639
09-08-2019 03:19 AM
LiorOrkin
Hello
I was wondering if it is possible to use collector to open a specific sent survey.
i.e
Choosing a point or an polygon in collector and using it to open the Survey123 sent box with the survey i want to edit.
Thank you
Lior
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Lior,
At this time, the Survey123 URL parameters do not support opening an existing survey in the field app.  This has been introduced for the web app; see Survey123 Tricks of the Trade: Editing records in a web form
Jean-SebastienLauzon
New Contributor III
Can we expect that to become possible in the near future?
DougBrowning
MVP Esteemed Contributor
You can edit in directly in Collector  but of course it would not be a smart form.  Are these for repeat visits?  If so I always like those to be separate forms.
