Use Pulldata table or external feature class to feed location data to Survey123
441
04-04-2020 09:19 PM
Steve_Kennedy_VNC
My Survey123 respondents will be using a browser to access the survey and are having trouble allowing Safari access to the device's location.  I would like to remove the Geopoint question and instead use a choice question for the user to select from many named locations, and pull the coordinates from that feaures class.
E.g. user selects Station1 and the location of Station 1 is copied from the Station feature class to populate the Geopoint lat/lon values.
Thank you
JamesTedrick
Esri Esteemed Contributor
Hi Steve,
Take a look at the 'Calculate Locations from CSV file' sample in Survey123 Connect to see the pattern.  Note the geopoint question must still be present (though it can be read-only).
Steve_Kennedy_VNC
Worked perfectly, thanks.
