Usar una capa de datos georrefrenciada
445
04-13-2022 07:19 AM
GerardoContreras
Muy buenos dís a todos, tengo una capa de datos ya geocodificados y me gustaría poder usar esa capa para construir un formulario en connect y no perder esos datos.
¿Se puede realizar con survey123 connect?
Alguien me puede ayudar o darme algun link para leer sobre el tema o ejemplos.
Saludos.-
Good morning everyone, I have a data layer already geocoded and I would like to be able to use that layer to build a form in connect and not lose that data. Can it be done with survey123 connect? Can someone help me or give me a link to read about the subject or examples. Greetings.-
Katie_Clark
MVP Alum
Hello! You can build a survey off of an existing feature service, would that work for you?
https://doc.arcgis.com/en/survey123/desktop/create-surveys/survey123withexistingfeatureservices.htm#....
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
