I've created a Survey123 form using the ArcGIS Survey123 Connect. One section of the form should enable users to upload multiple files. I've used to file question type with multiline appearance.
If I open the form using the mobile app, everything seems to be working fine.
But when I use the web browser option, I can upload a single file only.
This survey is published to ArcGIS Enterprise 10.8.1
Appreciate any help or directions in this regards!
Majdi
Hi Majdi,
What version of Connect are you using to publish your survey? By default, version locking is enabled for your surveys. This means that surveys are rendered using same version of the web app as was used to publish the survey in the first place. Eg a survey published in Connect 3.9 will be rendered using the 3.9 version of the web app.
The file question type supports the 'multiline' appearance from 3.10 onwards. If you're using an older version of Connect (eg 3.9 or earlier) you will need to change the survey settings so that it always uses the latest version of the web app to render your survey. This setting is found in the 'Settings' tab:
Hope this helps,
Brett
Hi @BrettStokes,
Thanks for your reply!
I already set my survey to always use the latest version, but still have the same issue.
Any thoughts!
