Updating repeat records when the form is submitted
810
10-09-2024 04:53 AM
KatieQuantrell
I have created a Survey123 form to collect survey data for several points along a transect. The data for each survey point is held within a repeat in the survey and general information about the transect is held outside of the repeat. To aid output data usability I am pulling all the generic transect information fields into the repeat table in AGOL.
For the time that the transect was completed ('End Time') however as this field is only filled in within the form once the last survey point has been collected, it is appearing blank in the data submitted for all the point records in the repeat apart from the last repeat record. I assume this is due to the fact that the 'End Time' field will be blank when the first set of repeat records are added, but the final record is created on submission of the form (i.e. once there is data in this 'End Time' field).
Is there a way to auto update the earlier records in the repeat with the data entered within the 'End Time' field once this has been populated? Without having to go back through all repeats to manually edit them. Resulting in this field being populated for all repeat records once this data is submitted, not just the last repeat record.
Many thanks for any help/advice
DuncanC
The root of your problem is copying data from the parent table to the child table 'to aid output data usability', I get why people do this, but IMO it's a bad practice and should be avoided unless you really can justify why it's worth it in a particular case.
If you instead just access the data from the parent and don't try to have duplicate data in your child table that would solve your problem.
The alternative is a script that updates the child records once the end time is available.
DuncanC
KatieQuantrell
Many thanks for your reply, we've now written a script to update the records on AGOL.
abureaux
MVP Frequent Contributor
This is expected. Repeats only run calculates for the active item. If you manually scroll back through the repeat, you will see that the calculate fills in. No way to chance that behaviour just now, unfortunately.
This shouldn't be necessary. As the common data is stored in the primary table, it is already associated with the repeats. If you need to pull data from the parent table into a repeat item within a Feature Report, you can use dot notation. E.g., Instead of pulling ${username} from the main table into a repeat, you can just use something like ${PARENTLAYER.username}. To get PARENTLAYER, open Connect and go to the "Schema" tab. The "Layers/Tables" column has the names you need.
No. See first point above.
