Updating calculation from various fields
325
12-03-2019 09:58 AM
KerryKang1
New Contributor II
Hello all,
I have a question for showing calculation result while data is being entered.
There is a label showing 'Total Value' where the values are added from item 1 - 10. My current calculation is
${item1} + ${item2}  + ${item3} +${item4} + ${item5}  + ${item6}+${item7} + ${item8}  + ${item9}+${item10}.
The problem with this method is that the Total value is not updated until all 10 values are added. Users may enter values for all 10 items or maybe only 8 or even 5. How can I make the total value updated as each item value is entered, not waiting until the last item value is entered?
I could use repeat and  using sum for item but this will create nested repeat for my survey, and I cannot use as this survey needs to be opened through web browser.
Cheers,
IsmaelChivite
Esri Notable Contributor
Hi. If any of the input values in your formula is null, the output will be null. To work around this you can:
* Set a default value of 0 to all questions (using the default XLSForm column)
* Modify your expression as follows:
coalesce(${item1},0) + coalesce(${item2},0)  + coalesce(${item3},0) ...
KerryKang1
New Contributor II
Hi Ismael, this method worked perfect. Thanks!
Cheers,
