Update survey schema propogate to stakeholder and fieldworker
967
7
06-11-2019 02:21 PM
JasonCarter1
New Contributor III
I updated the schema of a survey and republished the changes. I noticed that the fields only changed in the hosted feature layer and not the stakeholder or fieldworker layers. Is this behavior expected? What is the best way to update all three layers so everything is synced?
Thank you
JamesTedrick
Esri Esteemed Contributor
Hi Jason,
Did you make the changes in Survey123 Connect or the Survey123 website?
JasonCarter1
New Contributor III
I made the changes in Connect. I cannot access the Survey123 website through my organizations portal. When I click on Apps, and launch the Survey123 website and log in with my enterprise credentials I receive the attached error. I'm not attempting to access a specific survey, just the website landing page.
an error
DougBrowning
MVP Esteemed Contributor
Did it maybe create a all new Feature service on you?  If it is a big enough change it will remake it.  This causes the itemid to change.  Your _stakeholders are views may still be pointing to the original feature service.  Turn on sharing again and see if new _stakeholder view appears.
Just a guess.
ElisabeteTeixeira
I did the same thing, I create an new choice of answer to the question in survey 123, but I noticed that the fields only changed in the form, and not in the stakeholder or fieldworker layers. I tried to making a new sharing but nothing change.
How can I have this updates synced in the others layers (stakeholder and fieldworker)?
Thank you
JamesTedrick
Hi Elisabete,
When was this form originally published?  There was an issue with updating the views after a feature service change, but that should have been addressed with the UC release in the web designer.
ElisabeteTeixeira
Hi, James,
Thank you so much for your answer,
we published the survey in 10/9/19. And today we tried again to make some
changings in survey, as you can see the form is update, but the others no.
There is a solution for this problem?
James Tedrick <geonet@esri.com> escreveu no dia quinta, 12/09/2019 à(s)
18:41:
GeoNet, The Esri Community | GIS and Geospatial Professional Community
<https://community.esri.com/?et=watches.email.thread>
Re: Update survey schema propogate to stakeholder and fieldworker
reply from James Tedrick
<https://community.esri.com/people/JTedrick-esristaff?et=watches.email.thread>
in Survey123 for ArcGIS - View the full discussion
<https://community.esri.com/message/877543-re-update-survey-schema-propogate-to-stakeholder-and-fieldworker?commentID=877543&et=watches.email.thread#comment-877543>
JamesTedrick
Hi Elisabete,
For teh stakeholder layer, deleting and re-sharing for viewing will correct the issue. It doesn't look like this form has a fieldworker view, correct?
