Hi all,
I'm using last version of Survey123 (3.0.127). After adding my Portal into Connections Setting, no windows appears after I click on login button.
Also when I remove portal connection and try to login into argis online account, no authentication windows pop-up.
Need help ASAP!
Cheers
Stefano
Hi Stefano,
The problem could also be related to the Windows Credential Manager we are currently seeing on some Windows devices, see this thread for more info: https://community.esri.com/thread/217614-cant-sign-in-with-survey123
Phil.
Hi Stefano,
A couple of follow on questions:
Kind regards,
Mikie
Hi Michael, thank's for the quick reply!
Michael Kelly ha scritto:
- What version of Portal are you using? Note Survey123 3.0 does not run against versions of Portal for ArcGIS older than 10.4 as stated in the release blog
10.51
What kind of device are you using - iOS/Android/iOS/Windows?
- Have you tried on any other devices/platforms?
- When you sign to ArcGIS Online, what appears - do you see Sign in to ArcGIS Online at the top of the page?
- Is the device connected to a restrictive network which would block ArcGIS Online? It might be worth trying over mobile network.
Kind regards,
Mikie
From Windows 10
Yes. Same problem.
Nothing special...
This issue has strarted after I change "ArcGIS Online" setting on Portal of my customer for using reverse geocoding with ArcGIS Online subscription in a Survey123 hosted on Portal.
After that I add a connection to Portal in Survey123 Connect UI. Then after my log-off, window authentication is no longer open.
Stefano
Hi Stefano - I suspect the problem you are seeing is related to this thread. Can you take a look at it and see if it helps?
When I asked "When you sign to ArcGIS Online, what appears - do you see Sign in to ArcGIS Online at the top of the page?", what I was really wondering is what the Survey123 app screen looks like when you try to sign into ArcGIS Online! Apologies for the confusion.
Mikie
Hi Stefano,
Phil.
Hi Philips, ok thank you
