Unable to republish my survey using Survey 123 Connect
338
10-07-2019 05:26 PM
Ness2
I am unable to republish any of my surveys (using Connect 3.5.157).  I have tried this on several different surveys.  I can publish new surveys but not republish.  There is no error message, it just hangs after hitting the publish button.
I saw there was a similar issue that people experienced due to a login issue but I am logged in just fine.
I haven't used S123 for a while but it used to be very easy to republish.  Suggestions?
JamesTedrick
Esri Esteemed Contributor
Hi Vanessa,
Have anything happened to the surveys in your ArcGIS account, such as moved folders or changed owners?
vanessagiles
No, neither.  I might try upgrading to the latest version of Connect and see if that helps.  Any other ideas?
