Tracking movement in Survey123 map
197
09-14-2021 09:15 PM
EmilyRayner
Hi all, is there any new development with maps in Survey123 where in maps you it can follow your movements and plot a path? Rather than manually having to plot your path. Thanks
Philip-Wilson
Esri Frequent Contributor
Hi @EmilyRayner,
GPS streaming for line and polygon collection is not supported and is not currently planned for the upcoming release. We do have an issue in our backlog to support this feature in the future. You can refer to following support bug for status:
ENH-000125836 Stream locations when capturing geotrace/geoshape.
For the currently supported ways you can capture lines and polygons in Survey123, please refer to:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/geotracegeoshape.htm
Regards,
Phil.
Philip-Wilson
Hi @EmilyRayner,
Regards,
Phil.
DougBrowning
MVP Frequent Contributor
I thought this was mentioned in one of the UC videos?  I swear @Ismael  said this was coming to 123.
Philip-Wilson
Hi @DougBrowning,
In the UC presentation we mentioned adding support for tracking (similar to Tracker) in Survey123 in a future release in the road map, however this is different to streaming the geotrace/geoshape locations for the geometry of the feature using the map question.
The tracking capability will use the Tracker feature layer, similar to Field Maps, and we are currently working on implementing this in QuickCapture first, and then Survey123.
Regards,
Phil.
EmilyRayner
Thanks for the response. I will keep checking in, it would be very helpful with our program.
