I'm trying to get aerials available for offline use in Survey123.
Therefore I created a TPK an uploaded that file to ArcGIS Online.
However, I'm unable to find the TPK in Survey123 via linked Content --> Add Map Link.
I initially thought that this is because of the different spatial reference. However, I reprojected the raster and the TPK to be inline with other TPKs that work for me (ESRI Aerials), and still, I can't find the TPK.
Did I miss something?
Here the reference:
And attached a test TPK.
Thank you,
Marco
Hi Marco,
Aside from the Linked Content approach, you can also copy the TPK to the media folder and publish the form with it attached.
That's true James, but not really what I want to do.
Especially if I want to give the fieldworkers the freedom to choose their AOI. Also the area (and consequently the TPK) would be too big to publish it along with the survey.
Hi Marco,
As the documentation indicates, the linked content is used for online maps (web maps) with the in-beta mapping engine. I've noted the request to make offline maps (tile packages) available via that workflow as well.
I'm just wondering why I 'm able to find the TPK from the ESRI Aerials, while I can't find the other(s), although they are (geo)-technically the same.
