The Search() appearance for Multi select question in survey 123
1868
11-21-2022 01:20 AM
KwabenaDenteh1
Hello Community,
I would want to know if any one has tried the search appearance for multi select question in survey 123 connect using CSV file in the media folder of the project instead of a url of a feature service and I would want to know know if it works because mine is not working
ZacharySutherby
Hello @KwabenaDenteh1
The serach() appearance is supported on select_multiple questions. I've attached an example demonstrating the workflow. Please also refer to this documentation
Thank you,
Zach
Sghimire
Can you please attach the Survey123 xlsx file? I tested the Search() appearance on select multiple questions but it's not working. Thanks.
SaraMendiola
Hi, I'm trying this and the search function still isnt working. Also based off your attachment, it doesnt seem like you're referencing a CSV file.
Type would be 'select_multiple_from_file XXX.csv' instead of just 'select_multiple county'
RobertAnderson3
MVP Regular Contributor
The attached XLSX (found in the ZIP file) does reference a CSV, the naming convention "from_file" doesn't seem like it's necessary any longer.
The one thing I will mention (and what I originally thought this thread was about) is that while select_multiple works with a search() appearance, it does NOT work with autocomplete which I really wish it did, as without it I can't really take advantage of it.
