tab through data entry on Survey123 form on PC
759
12
07-18-2019 10:05 AM
JamesKelly4
Is it possible to configure my Survey123 form so that folks entering data via the PC version of the app can tab through the data entry (instead of clicking through)?
JamesKelly4
Looks like you can tab through, but is there a key that will select the answer that is highlighted?
JamesKelly4
Survey123 Geonet‌ can you help me get my question answered? Thanks!
Philip-Wilson
Esri Frequent Contributor
Hi James,
The tab key is supported on desktop platforms, however not all question types in the survey can be tabbed through. It is possible to tab text, integer and decimal questions, however other question types that do not have an input box or support the tab key will be skipped.
Can you expand further on what you mean by "is there a key that will select the answer that is highlighted?"
Phil.
JamesKelly4
Thanks Philip. I mean when tabbing through on most forms you can hit enter to select a highlighted response. For Survey123 on PC it looks like you have to click to select a response. I was wondering if there was a keyboard shortcut to select a response. Does that make sense?
Philip-Wilson
Hi James,
Ok, understand. No currently there is no way to tab through via shortcut key on enter.
Phil.
ChrisWoodward
Hey Philip, is there a way for Survey123 to support using tab on mobile platforms?
DougBrowning
MVP Frequent Contributor
Yea I second this one.  In Filemaker it actually just goes to the next question for you (and will even drop down the drop down automatically for you).
In mobile just enable the button to be Next instead of Done.
Would really help with data entry speed.
Philip-Wilson
Hi Chris/Doug,
In the upcoming 3.6 release we have made some improvements to the input controls (and other supported controls) to enable tab/enter to work correctly on desktops, as well as improving the enter/return key on mobile devices to tab to the next input field. The default keyboard behaviour now uses a custom enter key (on iOS and Android) all the input controls have been updated. There will still be some controls that do not support the tab or enter key, as they do not have a focus box, however this will be something we continue to address in the future.
The next beta builds available on EAC will include these improvements.
Phil.
DougBrowning
Thank you Phil!  I am glad to see that the UI is starting to get some attention.
Will it just do to the next field or will there be control?  I was thinking a new column like fieldorder that you could number 1,2,3 or 100,200,300 in blocks.
