Syntax for bind::esri:parameters to show all previous repeats?
2280
05-18-2018 05:42 AM
BrentKinal1
Occasional Contributor III
I am having trouble coming up with the proper parameter to display all previously entered repeats for a survey when opened via the inbox. I would also like to prevent editing of previously entered repeats if I can get them to come into the inbox. Any insight on the proper parameter syntax would be greatly appreciated. I am hoping this might help the problem I am having here: https://community.esri.com/message/772411-count-and-sum-fuctions-for-repeat-in-inbox
Thanks!
BrandonArmstrong
Hi Brent,
Please refer to the following document regarding syntax that can be used when displaying/editing repeat records via the Inbox...
Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS
I believe the syntax you are look for is 'query=' in the bind::esri:parameters column of the begin_repeat row.
This should allow for all records within the repeat to be displayed without allowing edits.
Best,
Brandon
BrandonArmstrong
Hi Brent,
Best,
Brandon
MichelleWilliamsERM
bind::esri:parameters -- I'm looking for a few more samples than those provided in the link above:
query=afterCountPhoto>1 (greater or less than)
query=afterCountPhoto=NULL (not=)
Thank you in advance @BrandonArmstrong
