Survey123 with Portal 10.7.1 - Error 404
1464
10-08-2019 10:21 AM
deleted-user-AyQ-Iok8btBJ
New Contributor II
I am trying to connect Survey123 to our new Enterprise Portal. Our Portal is federated with ArcGIS Server and our security is managed by AD. I can successfully get to the Survey123 site using our portal url (https://survey123.arcgis.com/?portalUrl=https://exampleportal.esri.com/arcgis) but when I click 'Sign In' I get a 404 error:
I have gone to my ArcGIS Server Administrator Directory and added survey123.arcgis.com as an AllowedOrigin
Any ideas what could be going on here?
JamesTedrick
Esri Esteemed Contributor
Hi Neel,
Can you provide more details about your ArcGIS Enterprise setup?  Version, Windows/Linux?
New Contributor II
10.7.1 on Windows
JamesTedrick
Hi Neil,
Thanks, this resembles an issue with the Java web adaptor, but that was addressed before 10.7.1.  As this apparently deals with an ArcGIS Enterprise configuration issue, can I ask you to open a ticket with Esri Support to troubleshoot this?
by Anonymous User
Not applicable
Removing /home from the Portal url should resolve the issue.
parksh
New Contributor II
Hello @Anonymous User
I have same issue with this post.
But I cannot figure out where the /home text in Portal url.
Can you describe more detailed workaround?
Also, I check below article. But this document also doesn't helpful.
 - https://support.esri.com/en/technical-article/000023188
