Survey123 Windows 10 - Where are forms download at?
87
04-18-2019 05:43 AM
Occasional Contributor III
On a windows 10 PC what folder are the survey123 forms downloaded to?
Tags (1)
Reply
Esri Frequent Contributor
Hi Jordan,
Survey123 forms are downloaded to: C:\Users\{username}\ArcGIS\My Surveys\
Phil.
Hi Jordan,
Phil.
MVP Frequent Contributor
Are you still considering moving this to My Documents so that most corporate IT systems back it up?  Currently mine does not get backed up because of this and I have lost it all once already.  The current location is very strange.
Ideally I wish I could just pick any dir I want.  And be able to switch between multiple directories - so I can change projects easily.  Kind of like Projects in Pro.
Right now I have almost 50 forms in my Connect!  Trying to get them all straight is more work than the form.  If I could load a dir of just each state....sweet.
Also a better way to list them in connect.  Due to naming standards all 50 forms are "XYCompany Program ..." which makes telling which is which impossible.
Thanks
