Survey123 website portal login
785
06-19-2019 08:19 AM
peterbrad2
I used to be able to login to the Survey123 website using my portal login information to see surveys published through our portal. I would copy the URL to a browser and it would direct me to sign in using my portal account. Now when I try the same method it redirects and asks me for my ArcGIS Online account? There is an enterprise login but I've never seen or used it before (the login starts ends with .maps.arcgis.com)
I am using the following portal URL:
https://survey123.arcgis.com/?portalUrl=https:/arcgisweb.src.sk.ca/arcgisweb
BrandonArmstrong
BrandonArmstrong
Hi Peter,
It looks like you are missing a '/'.  Try  https://survey123.arcgis.com/?portalUrl=https://arcgisweb.src.sk.ca/arcgisweb
peterbrad2
Great! Such an easy fix I should have caught that. Thanks, Brandon.
-Pete
