Survey123 Web Form | Bug on calculates within repeats
650
05-06-2021 04:33 AM
UhullGoGoGoGo
New Contributor III
I'd like to report a bug on calculates within repeats of web forms.
The calculate fields from the first inserted item are always
updated accordingly the last modified item, causing wrong
calculation values being sent to the data store.
The same problem doesn't happen with the field app.
Form:
Behaviour on the web:
Error web formError web form
Behaviour on field app:
Published with Survey123 Connect 3.12.230
grahamthibault
Hello,
Have you been able to resolve this error?  I have been developing a form with a repeat that has calculated fields and have recently noticed the same outcome in the web form only.  The first record's calculated attributes are being recalculated based on the subsequent entries in the repeat.  I have been testing this error using different browsers and devices with the same outcome in the web form.  I did not notice this error until recently.
Any assistance you could offer would be greatly appreciated.
Published with Connect 3.12.232
UhullGoGoGoGo
New Contributor III
I've contacted tech support. It's a BUG =/
