Survey123 Web Browser: Survey Footer/Header still display when turn off
3382
7
09-13-2019 08:33 AM
AlexP_
Hello,
Please see two screenshots. I have survey123 web browser (AGOL) from survey123 connect with existing secured feature service. Is there a way actually to turn off the survey header and footer? I published it and it is still display survey123 header and footer on web. Please advise. Thank you
cc: Survey123 for ArcGIS
survey123_for_arcgis‌ survey123web #survey123
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
I can see what you are describing regarding the header/footer display switches not working.  As a workaround, you can share the survey with ?hide=header,footer appended on the full survey URL (https://survey123.arcgis.com/share/<SURVEY ID>?hide=header,footer).
James
JamesTedrick
Hi Alex,
James
AlexP_
James,
Thank you for your reply. This is very helpful.
Alex
BrandonArmstrong
Hi Alex,
Thank you for reporting this behavior.  This has been identified as a defect, and has been raised by Esri Technical Support as BUG-000125151.  While we look into investigating this further, it would be helpful if you could please contact technical support and have them create a case that can be added to the bug.  This helps the team keep track of Survey123 users who are affected and can also help in prioritizing defects to address.
Best,
Brandon
ZhifangWang
Hi Alex,
BUG-000125151 has bee fixed in the 3.9 release
Thanks again for your feedback.
KeizzyAnpalagan
New Contributor II
This bug still isn't fixed. I'm having this issue currently.
by Anonymous User
Not applicable
Hi Keizzy,
Have you tried re-publishing your survey with 3.9 and also clearing your browser cache.
Regards,
Phil.
KeizzyAnpalagan
New Contributor II
Hi Phil,
I have tried re-publishing with 3.9 and also clearing the browser cache.
-Keizzy
