Survey123 web app - Geopoint to automatically update to the Device's current location
1584
05-04-2021 05:24 PM
GFernando
New Contributor III
In the Survey123 field app - if a default is not provided to a geopoint question, it will automatically update to the device's current location. Is this same functionality possible in the web app?
Gee
by Anonymous User
Not applicable
Hi @GFernando,
Due to the way that modern web browsers work and that websites are required to ask for a users permission before using their location, it is not possible to automatically set the devices location if no default is set. The permission acceptance must be set first, and after that the user can use their current location using the button to select it.
Regards,
Phil.
by Anonymous User
Not applicable
Hi @GFernando,
Regards,
Phil.
GFernando
New Contributor III
That makes perfect sense. Thanks @Anonymous User for the explanation 🙂
by Anonymous User
Not applicable
Hi @Anonymous User,
I was wondering, is it possible to automatically prompt a user for permission? I tried everything on Android and iOS devices, and it always comes down to clicking on the map, then 'allow' on the prompt that shows up and then clicking the button to locate the user. Is there any option to short-circuit this process? E.g., automatic prompt for location and, if given, automatic location? My aim is to hide the map (which is paired in repeat with an image question), so the user would only see the prompt for location and that's it.
I attached my simple survey.
Many thanks,
Mateusz
by Anonymous User
Not applicable
Hi @Anonymous User,
Due to the way that location services and user prompts work in web browsers, unforutnately they current way it prompts based on interacting with the map question is the limitation. We can not have a prompt for location if there is no reference in the survey (the web browser page loaded) to the location being used for that purpose (such as a map or address question).
Regards,
Phil.
