Survey123 web app - calendar pop-up in the way
520
10-31-2022 09:16 AM
RebeccaL
Hi all,
I'm a newbie to creating a Survey123 and while my surveys seem to be functioning properly, the display in the web app isn't correct. I've attached a screenshot to show that in the web app, the calendar pop-up isn't collapsed and is in the way of the other fields. I've set the default date/time to now() so users can skip using the calendar, but I'd like to fix the appearance. What's gone wrong? Any hints or tips?
IsmaelChivite
Esri Notable Contributor
It does not look like you did anything wrong with the form design. This is likely a problem in the Survey123 web app. Can you share a link to your survey?  If you do not want to share here in Esri Community, please open a Tech Support Incident.
