Survey123 uses location services in background - drains battery fast!
1761
15
03-11-2019 04:55 PM
TasmanianIrrigation
When Survey123 (version 3.3.26) on iOS asks permission to use Location Services, I select the 'while using the app' option.
If I check iOS' location services settings, it shows that Survey123 is configured to use location services while using the app and not 'always' or 'never'.
Nevertheless, any time after launching Survey123, it uses location services continuously, whether Survey123 is running on screen or even when it is in the background (and even if the device is idle - I think) and drains the battery very fast.  This is occurring for a number of our users and is causing serious problems here.
Is this a known problem?  Are there any known fixes or work arounds other than killing Survey123 when not in use (or disabling location services when not in use)?
We do not have this problem on our older iOS devices which can only run version 2.8.2 of Survey123, and we only started having this problem on our newer devices recently.  I think it may be related to the recent update of Survey123.
Even if this was working properly, it should not drain the battery this fast.  Does Survey123 allow deferred location updates?  This dramatically increases battery life in the location-aware apps that I've written.  (see:  allowDeferredLocationUpdatesUntilTraveled:timeout: - CLLocationManager | Apple Developer Documentati...  )
(also see:  locationManager:didUpdateLocations: - CLLocationManagerDelegate | Apple Developer Documentation  - the old way doesn't work with deferred location updates).
MichelleWilliams1
Occasional Contributor III
Our Apple devices are also having this issue.
~ Following
DougBrowning
MVP Frequent Contributor
Bump.  We are having lots of users asking us why the GPS is on the entire time the app is open.  Even with no form open.  Our forms are long and can be open for hours.  With continuous GPS access the battery is going fast.  They are asking to open, then turn off the location but I do not love this idea.
Also we are seeing android is constantly complaining the 123 leaves the GPS on even when it is in the background and it asks to close it.  Which caused some users to lose data.  Collector does not see to have this issue.
It is really hurting the number of hours the battery will last.
thanks
DougBrowning
Still seeing warning messages from Android that the GPS is always on, even when the app is in the background.  iOS gives no warning but it is draining also.
Not seeing this on Collector so there must be some way to fix this.  I even set the app to Only use Location while using the App and it still gives this warning.
In addition We have forms that take hours to complete.  This means the GPS is running all day long, which drains the battery fast.
Could we maybe have a button to turn the GPS on/off at least?  Like make the button that is there now a toggle or something, then a long press for options.  We could save hours of use that way.
Thanks for looking
KingstadVictor
We are experiencing the same problem. Is there any news about this issue?
thanks
CrystalCornejo
We are having the same issue. Our users don’t want to use the Survey123 app because it’s draining their phone/tablet batteries. We don’t have to fully close Collector for location services to stop, so why do we for Survey123?
DougBrowning
Trying a bump again since it has been 2 years now.  We have forms that take hours to complete and this is draining a lot of battery.
Maybe a quick way to turn off the GPS for the rest of the form?  Like just tap the icon and it shuts off for the rest of the form.
This is getting asked for Field Maps also now  https://community.esri.com/t5/arcgis-field-maps-ideas/ability-to-turn-gps-off/idc-p/1040409
Please consider.  Hate to bug you by tagging you but we keep running out of battery on site and its hard for us to carry chargers and such since a lot of it is hiking.
Thank you!
@JamesTedrick @IsmaelChivite @Philip-Wilson
