When adding a Survey123 URL scheme for a native Survey123 app (not webform), in a pop up window of a AGOL webmap, the hyperlink first opens a blank web page, before opening the survey123 app and corresponding survey. Is there a way to get rid of that blank page opening first...?
Here's the href I'm using:
<a href="arcgis-survey123://?itemID=2dcb6f0f041f4b64be71fb993d4731e4" target="_blank">Open survey</a>
Just noticed this seems to have been since fixed/changed - the blank web page gets created but then auto-closes which is great.
Chaim,
target="_blank" is actually what you use to open a in a new page.. however removing it does not stop the blank page from opening when linking from popups in the map viewer. It would appear that opening a new page or tab is baked into how links in the map viewer popups work, even when linking to an App.
I tried a few variation of your link, but could not find an easy or quick workaround to this.
Mark
Thanks for confirming. Yes, changing the target tag didn't help me either.
