Hello, I have a survey that has been in use for a few years now, I've made several updates throughout that time using Survey123 Connect. On the most recent update we are adding a several fields but none of the choice lists have changed, and none of the existing fields were deleted. When I try to publish it indicates that the survey has already been published and then lists the fields not found. I click on the "Add the following fields when publishing" then click publish survey. At this point the process seems to get hung up. It says "Getting information and the dot wheel just continually spins. I've let this go for several hours, it never progresses past getting information nor does it ever give an error message.
I have Survey123 Connect v. 3.12.232
I tried to turn off the web map option to see if that made a difference, it did not
The file has never changed, it's the same as when it was first created.
Please help!
