Survey123...Turn an image question off when it is answered
275
06-10-2020 11:23 AM
RobertBorchert
Frequent Contributor III
You can use the relevant column to turn a question on based on a previous questions answer.
I have one survey I made that is getting quite long.  I would like for there to be a way so that a question disappears after it has been answered.  Specifically image types.
RobertBorchert
What I can do is make the question turn off after I answer the next question.
DougBrowning
This may change the value to '' - it does on regular fields whenever they hide.
The new beta has a way to hide without using relevant.
I just use pages so only so many per page.  I like it.
Hope that helps
DougBrowning
You can now try the new visible style now in the new version.
See https://community.esri.com/groups/survey123/blog/2020/10/19/whats-new-in-survey123-october-2020
