Survey123 supportsApplyEditsEithGlobalIDs must be true error
3924
10
07-31-2018 07:40 AM
JakeJacobs
I am publishing a Survey123 survey from a feature service in ArcGIS Enterprise 10.6.  I have Survey123 Connect 3.0.127 and Survey123 3.0.132
I had been publishing against 2.7 and then when upgrading, discovered the new requirement for supportsApplyEditsWithGlobalIDs must be true. My feature service had this as false.  So I enabled archiving on my (nonversioned) dataset and republished, and now the parameter is true in my featureservice (see attachment)
However, my survey is still failing. To test, I have created a survey from the feature service item but have only one text field exposed in the survey.
The feature class has a related attachment table, using globalids as the foreign key. Everything is being created with python (2.7)
I am creating brand new featureclasses in oracle SDE for this project, so can make schema changes if necessary. I just don't quite see what they should be.
The globalid index on both the featureclass and the attachment table are unique after enabling archiving.
Hoping someone can point me to what I'm missing,
JakeJacobs
I just wanted to close the loop on this one and report that re-installing the app fixed the problem.  I saw that another user had tried that and had success so I did the same.
