I have successfully created a flow from my survey123 survey created from connect to an excel online file. I can get the flow to add new rows to the table. However, after several attempts and trialing a few other forums suggestions, I still cannot get the flow to trigger, let alone update an existing row in my table, when editing and resending a survey from the inbox or sent folders of the ios app. I have tried using the objectId as well as calculated uuid() for indicators. The flow itself will also perform without error, but when tested for a resubmission, it is not triggered.
Can someone provide a template on how to "update a row" in an excel file when an existing survey response has been edited from the ios app?
Hello Taylor Schyrbiak,
In the Survey123 website if you navigate to Settings > Webhooks > Edit webhook is "Existing record edited" enabled for Trigger events?
Thank you,
Zach
Thank you,
Zach
Yes, that was it! I guess mine were all defaulted to off.
Sent from my iPhone
Sweet I am glad that worked out! Unfortunately with the Survey123 Power Automate connector monitoring for updating records is not enabled by default.
- Zach
Do you mind showing your flow with any expressions clearly shown. I'm trying to do the same thing but not having any luck with the updating of a row.
