Dear All,
Have any of you experienced once in a while or suddenly recently?
Survey123 is suddenly not working with our Portal for ArcGIS.
I saw this on browser console:
msgport.js:70 {"notify":"init_tab"}
main-v3.16.173.js:2
ERROR Error: Uncaught (in promise): Object: {"error":{"name":"ArcGISRequestError","message":"404: Service Hosted/service_c0dba7c083bb41e89170100f34c18545/MapServer not found ","originalMessage":"Service Hosted/service_c0dba7c083bb41e89170100f34c18545/MapServer not found ","code":404,"response":{"error":{"code":404,"message":"Service Hosted/service_c0dba7c083bb41e89170100f34c18545/MapServer not found ","details":[]}},"url":"https://OURDOMAIN/server/rest/services/Hosted/service_c0dba7c083bb41e89170100f34c18545/FeatureServer....","options":{"httpMethod":"GET","authentication":{"username":"adm","token":"XXX","tokenExpires":"2023-01-12T16:48:50.311Z","portal":"https://OURDOMAIN/portal/sharing/rest","ssl":false,"tokenDuration":20160,"refreshTokenTTL":1440},"params":{},"headers":{}}}}
at P (main-v3.16.173.js:2:3540989)
at main-v3.16.173.js:2:3541663
at e.invokeTask (main-v3.16.173.js:2:3531335)
at Object.onInvokeTask (main-v3.16.173.js:2:243546)
at e.invokeTask (main-v3.16.173.js:2:3531256)
at t.runTask (main-v3.16.173.js:2:3526410)
at y (main-v3.16.173.js:2:3533675)
Ro @ main-v3.16.173.js:2
Enterprise Version 10.9.1
Survey Versions: 3.16
None of our surveys are working now...
Solved! Go to Solution.
Resolved:
Restrict cross-domain requests to ArcGIS Server—ArcGIS Server | Documentation for ArcGIS Enterprise
Step1: Change AllowedOrigins from * to *,https://survey123.arcgis.com
Step2: Reboot ArcGIS Server service
Hello @rsun_TQB,
Are you able to access the REST endpoint URL from the error message (https://yourdomain/server/rest/services/Hosted/service_c0dba7c083bb41e89170100f34c18545/FeatureServe...) in a separate tab? Are you able to add that service to the map viewer?
Since the issue is happening for all your surveys I would suggest reaching out to Esri Technical Support to take a look into the issue. There may be a configuration issue with your ArcGIS Enterprise organization that's impacting Survey123.
Hi @ZacharySutherby ,
It sometimes gave me this message:
The survey is not accessible or does not exist.
Please ensure the signed in user (admin) can access this survey and that the survey link is correct.
I am already login on the portal as an admin.
Or it will keep loading forever, and I check the console got the log mentioned above.
I tried the rest URL, and get the following error:
{"error":{"code":498,"message":"Invalid Token","details":[]}}Something is wrong...and I have already contacted Esri Support, but they haven't been able to provide me solution just yet...
Reno
Resolved:
