Can anyone tell me why I am getting the "Choices:Name" value on a "select_multiple" and "Choices:Label" value on a "select_one" in the XLSForm back as a selected value for a survey, when actually it should only be the "Choices:Label"???
Shouldn't this be consistent?
Thank you for any assistance,
Bill
Hi. You may want to share a simplified version of your XLSForm. Both select_one and select_multiple should return the name values from your choice lists, rather than the labels. The reason why name values are returned is because labels can change in multiple-language surveys.
Thank you Ismael.
That makes total sense...especially when de-serializing the Json object into a C# class file. How does one "share" a file here?
To attach a file to a message in GeoNet, click on the 'Use advanced editor' link.
Thank you very much for that. I didn't even notice. I just got off the phone with an Esri Rep and he was able to re-produce the issue at hand with a simple XLSForm of his own. He says the issue is not an existing bug being worked on, so he created one for me. The "Select_One" options are the culprits. I will update this once I hear something.
Bill
This has now been declared as an official bug by an Esri Representative. The view of the collected data from a survey is reflecting an incorrect value in the table representation....
BUG-000105560 : Survey123 for ArcGIS stores correct survey values in associated feature service, yet values are not displayed correctly when viewing survey results via Table view in survey123.arcgis.com website
