Survey123 Save As is not working
566
04-06-2022 08:01 AM
SFM_MickieSmith
The Survey123 Save As is not working anymore... Click Save As -> Click Create Survey and nothing changed to let you know the copy was successful. Next, clicked the cancel button and refreshed the screen. A copy was created and it showed the same name. Then, verified the name of the folder created on the computer.  It created a new folder with the new name. I deleted the copy without losing the original survey.
However, I could not publish any updates to the survey after deleting the duplicate app. The folder in AGOL was deleted. Code error 400.  I had to rebuild the app. I think the Save As stopped working after the AGOL and Survey123 upgrade in March 2022.
DeonLengton
Hi
From what you are explaining you accidentally deleted the survey on your local computer AND the survey as it was published in ArcGIS Online.
Survey123 does warn that it will delete the local copy and the AGOL versions of it though:
Normally if i want to delete a survey I click on the three dots of a survey, then choose Open Folder, then delete the folder locally on my computer:
You will still have the survey on AGOL and can download the design files if you need it.
