Survey123's custom URL Scheme
1812
12-14-2016 11:08 AM
josuedi
New Contributor III
Hi! Ismael Chivite
I followed the steps you have shared about integrating survey123 with Workforce, for example, and you have not allowed me to perform the fields that I want to update. Below I leave a picture about the problem I have.
I have Android and the survey123 version is 1.9.24. I have administrator privileges and I have reviewed the fields that I want to integrate but still nothing. I hope you can help me, thanks in advance for any help you can offer me.
Thank you!!
Problems with Survey123
IsmaelChivite
Esri Notable Contributor
Hi.  Looking at the screenshot you provide it looks like the HTML link you added to the assignment description is not  correctly setup, because only a small portion of your custom URL scheme call is highlighted as a link.  This may explain why the survey  is not launched and the data not passed to it.
In this discussion: https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche...  you can see an example where the integration was achieved. Note that the whole  URL scheme call is highlighted as a link. I am just  guessing as to what could be wrong in your case.
deleted-user-GKyg-xriCvci
New Contributor II
Hi, I would like to ask if you ever found an answer for your question? I have exactly the same problem. I was searching through different threads on geonet forum but couldn't find solution for this issue. I want to use url scheme in workforce description and autopopulate several fields. But when I add the url, only small part of it is highlighted as a link. What is more, the same custom url scheme is working inside AGOL/collector and I am able to open the survey123. Does workforce require any special configuration? I saw one or two examples where this solution worked for people but my url looks the same as theirs. So I am wondering what might be the problem..
