Survey123 Response Order in Data View
960
08-12-2019 11:44 AM
JasonHerman
I have an employee who created a Survey. Then went back and added a few more questions. However when viewing the data in map or table form the newer questions columns are all placed at the end of the display. Is there anyway to force the display of the data to be the same order as it was collected in and NOT the order in which the questions were designed in.
JamesTedrick
Esri Esteemed Contributor
Hi Jason,
Are you asking about viewing in the Data Tab of Survey123 or another application?  If you are looking at the data in a web map, you can set the order of fields in the pop-up configuration of the layer.
LMedeirosUI
@JamesTedrick I am trying to sort the order of the columns in the data tab of the Survey123 web application. I am trying to use the map viewer in AGOL to re-order the fields/columns of the "_results" view layer, but changing the field order in the pop-up doesn't change the order of the fields in the table view. I've also tried changing the order of the fields in the pop-up for the hosted layer without any change to the table.
How do I change the order of the fields in a table?
Lea
