Survey123 Reports in feature layer attachments - webhook
434
09-13-2022 02:14 AM
TeslaTomislav
Hi everyone,
I would like to make the pop-up of the feature layer on the web map with an option to download a pdf attachment that will be generated through the Survey123 report.
That's not even a problem.
The problem is that when an attribute in the database is changed, the attachment is no longer up-to-date.
Has anyone created a webhook that will generate a new Survey123 Report for each attribute change and then replace the attachment in the pop-up (base)?
Tnx,
MichelleWilliamsERM
I don't use this function yet, but I could see where this could be useful.
I loved to see how you setup this up. 😀
