Survey123 - report template - attachment: signature
635
02-20-2019 02:39 AM
StefaanMinne
Before we had a test environment : 'a normal ArcGis'.  Now we are on a portal.
Before it was possible to have a survey 123 , with signature as image ( so attachment). It was possible to use the 'report' function and as a result it showed the signature on the word document.
Now on the portal this doesn't work anymore ....
Could this be the reason :
Feature report templates—Survey123 for ArcGIS | ArcGIS
Limitations
  • Attachments are not supported using the Survey123 website with ArcGIS Enterprise
How can I solve this, or what is a work around ?
Thank you
JamesTedrick
Esri Esteemed Contributor
Hi Stefaan,
As the documentation states, attachments are not supported when using an ArcGIS Enterprise context.  This is due to a difference in the attachment table in Online and Enterprise - Enterprise at this time lacks the ability for Survey123 to distinguish which attachment is associated with a question.
StevenGonzalez1
James,
Do you have any update on when this functionality will be ported to Enterprise/Portal?
JamesTedrick
I don't know of a specific timeline for support in ArcGIS Enterprise‌ (the feature needed is 'attachment keywords')
