Survey123 Report Photo not displaying
4474
11
02-02-2022 09:21 AM
ahagopian_coj
Hello!
I created a survey in Connect off an existing feature service that is hosted in AGOL.  I added an image question allowing the user to upload an image which works great.  However, I am unable to get the image to show in the report.  I can see it in the Data tab of the survey.  I can see it in a web map in AGOL.  But when I generate a report nothing is there.
Report attached.
Katie_Clark
MVP Regular Contributor
Hmmm, I've never seen an if statement used like that in a feature report template. If you take out the "if", does it work?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
ahagopian_coj
No, it doesn't.  The if statement was my attempt to see if there was a photo to please show it.  Here is it without it and it still won't display the photo.
Katie_Clark
Hmmm...Can you share your XLS Form as well so we can see how you have the survey set up?
Best,
Katie
ahagopian_coj
Sure!  The goal is to print a photo for each question but my first crack at this is just trying to print the Crawl Space photo with no luck.
Katie_Clark
oh! First thing I noticed is that you have esriFieldTypeString in the bind::esri:fieldType column
for the image questions. Get rid of that and see if it works?
If not I'll look a bit closer to see what I can find 🙂
Best,
Katie
ahagopian_coj
I did that but now get this error.
Katie_Clark
Is there already data submitted into this survey, or is it brand new? If there isn't any existing data, I would just republish the survey which will overwrite existing settings. It's throwing an error because you're trying to change a field type from text data to BLOB (image) data
Best,
Katie
ahagopian_coj
There is already data in it and its existing features.
ahagopian_coj
I created a "CRAWLSPACE_PHOTO" field but no data is in it. However, I can see the photo in survey123 under the "Data" tab.  I know the report uses keywords so I think its a syntax issue where I am just not calling the photo up correctly.
