We have a survey123 form that has several required fields that are only relevant if someone chooses a specific "crossing type." If they choose "bridge adequate" for crossing type, then these required fields are not relevant and do not appear. This behaves correctly in the mobile application, but when someone goes to enter data for a "bridge adequate" crossing type on the web form and submit, it will not allow it to be submitted and asks for the required fields. Help please!
Hi Kathleen,
Is it possible to share your XLSForm with us to look into this furter?
Here you go. Specifically, when someone selects "bridge adequate" as crossing type, most of the fields are not relevant/required.
https://drive.google.com/file/d/1XOOnSgR3Oq8yuEK7MAECarjJPpYG9_Vu/view?usp=sharing
Hello Kathleen,
Sorry for the late reply. I have looked into your form, and the quick fix is to replace space with "_" in the name column.
e.g. Use Bridge_Adequate instead of Bridge Adequate. The expression will be parsed and interpreted wrongly if space is contained in the name.
Ruth
