survey123 "there should be choice for this question"
2127
03-07-2017 04:21 PM
JenniferCasey1
When I try to save the attached form I get the error "there should be choice for this question." I have successfully replicated the samples online, but I must be missing something. Anyone know what I am doing wrong?
MarikaVertzonis
Hi Jennifer
A couple of things are happening here
1) you need to switch the choice_filter expression around ie: FacilityType=${Facility}
2) you can not use or_other (note the underscore, that was missing in your form too) in a cascading select. You would need to incorporate 'other' as an option in your choice list. To mimic the behavior of the or_other option and have an additional question appear on the form when Other is selected, create a question with a relevance dependent on the value of the select_one or select_multiple question.
Regards Marika
JenniferCasey1
thank you,  I tried so many different combinations of code, but I didn't realize I couldn't use "and other."  It works perfectly now.
