Survey123 PullData function working in Browser, but in not Mobile App
2446
13
07-11-2018 03:49 AM
BrianHiller
I have a survey123 form published that's using the pulldata function to select data from a .csv file and calculate the value/fill-in a few fields based on the results of a select one field. The survey works as expected when accessing the survey from a browser, but the pulldata function does not work on a mobile device (I have tested on Windows 10 and iOS).
Has anyone seen this before, I'm surprised this would work in a browser, but not in the survey123 mobile application.
by Anonymous User
Not applicable
Hi Brian,
Can you please provide a copy of the xlsx file you are using for your survey so we can take a closer look.
Phil.
BrianHiller
Can you send me your email address so i can send the file via email?
Brian
BrianHiller
my email is behiller@burnsmcd.com, please send me your email and I'll pass along the .xlsx file.
Brian
by Anonymous User
Not applicable
Thanks, have just sent you an email.
KimQuach
Hi Brian/Philip,
I also have the same problem using the Survey123 app.
Kim.
by Anonymous User
Not applicable
Hi Kim,
See my reply to Brian in this thread. Do you have commas in the data in your external CSV file being used for pulldata(), if so you need to remove them.
Phil.
KimQuach
Hi Phil,
No I don't have any commas in my csv.  If I open the file in a text editor, the commas only exists as column separators. Did you receive my csv/excel file from Ben?
Kim.
by Anonymous User
Not applicable
No, I don't have a copy of your external csv file, can you please send to me? Do you have any other special characters in the csv?
KimQuach
Can I have your email address so I can email you the file?  Sorry I thought I did, but checked my sent queue and did not have an email address for you.
thanks,
Kim.
